DRL Jazz 2014 v-tec.
Most vehicles nowadays have the facility to retrofit accessories and most of it is in place from the factory (as in wiring loom, fuses, etc). If they car was taken to the dealer for retrofitting lights, etc then it is a case of fitting the lights, putting power to the lights (fuse, switches, etc) and then programming it into the CanBus system to activate it.
1998 Civic Aerodeck 1800 VTI
Preventative Maintenance
Thanks again for your advice
what is this? 2024 model
Who remembers these?
New to Honda
Water in boot MK4 CRV
Dim low beam
- Remember this?
Dishonesty or Not???
- The old girl!!
The alternator will be engine ecu controlled also i think. - The old girl!!
