2014 CRV Brake Pads
I need to replace the pads on a 2014 CR-V AWD. I understand that this car can use different braking systems. Is there any way to tell the type of pad other than dismantling? The sevo has a Bosch sticker on it. Any recommendation for non Honda pads?
Regards
Ray.
I would run the registration number through Eurocarparts website and see what options they give you.
If you look at the Fitment tab that will show what the differences are.
Worst-case scenario, get both sets and return the one that is wrong
Good luck
