Hi,
I 'm trying to replace the AWD relay, as described in Honda service bulletin 15-012, but cannot see how to remove the left interior boot panel (see attached photo).   It seems to be a single enormous piece of plastic, but apart from a single clip on the bottom edge I can't locate any other visible screws or clips.
Does anyone know how to remove it?
Thanks.
It is more than likely that it just requires some brute force to remove (e.g. held in with metal clips) by using hands (not tools) to pull back the panel.
Maybe best to start at the bottom edge first.
There would more than likely be a screw holding the handle in place
