Nigel 15 Posted June 10, 2020 Posted June 10, 2020 I wondered if anyone has any advice about my problem. I have a 2011 CRV I dtec 2.2 diesel with 102000 on the clock. It had a full honda history up to 2 years ago but since then I have serviced the car myself using genuine Honda parts. The car wears the front tyres out in 10000 miles and also squeals badly when I go round a roundabout at any kind of speed. I am worried there maybe a differential problem front or rear. I wondered if the common rear differential issue would cause this?
Trevor Posted June 12, 2020 Posted June 12, 2020 Hi Nigel....welcome to the Forum The rear differential is a common fault with the CRV and requires the fluid to be changed periodically. Here is a link to the special fluid used: https://www.ebay.co.uk/itm/GENUINE-HONDA-CRV-DPS-FLUID-DIFF-OIL-1-LITRE/392495346713?epid=1415923714&hash=item5b628bb419:g:t-sAAOSwSONcM4GV If the fluid hasn't been changed for a while then it may require a flush. Link to flush kit: https://www.ebay.co.uk/itm/GENUINE-HONDA-CRV-2007-2017-REAR-DIFF-FLUID-FLUSH-KIT-SUPPLY-REG-FOR-WASHERS/293515954702?fits=Car+Make%3AHonda|Model%3ACR-V&hash=item4456ea0a0e:g:oCoAAOSwJHhcpIUk Let us know how you get on with it
Register a new accountSign in
