AVC Posted September 5, 2020 Share Posted September 5, 2020 Hello members, I have a Honda Jazz 1.6 petrol with a CVT transmission. I have a slight judder when initially taking up the drive from rest. I'm leaning towards the multi-plate clutches or start clutch but I need to test it first. Does anyone know where I can source the transmission technical data from to compare oil pressure data please. Quote Link to comment Share on other sites More sharing options...
Neil.H Posted November 12, 2021 Share Posted November 12, 2021 Hi the start judder is a common problem it's the start clutch , I changed the oil drove 500 miles and changed it again this fixed it but not for long , so I was told by a honda tech what they do is change the oil then do a clutch burn , car in gear brakes hard on and rev to 1500 for a second then do it again after second burn change oil again , I have never tried it and honda charge about £500 , but it will come back ,if you want the oil e bay is the cheapest for the genuine honda cvt oil , a start clutch kit is about £1600 then you need to get it fitted , my jazz had 110k on it but judder is not as bad as my wife's which only has 60k Quote Link to comment Share on other sites More sharing options...
FBogdan Posted April 18, 2023 Share Posted April 18, 2023 (edited) Just replace the CVT oil only with OEM Honda CVT-F. My Jazz is about to reach 200k km. I took it with juddering symptoms at 80k km. Judder appears usually after 3-4 years after oil change or 40-50k km range. I just change the oil and the magic happens again 🙂 Edited April 18, 2023 by FBogdan 1 Quote Link to comment Share on other sites More sharing options...
