HELP! Drive shaft replacement
I am in need to replace FR-V 2009 1.8l petrol automatic right hand (driver side) drive shaft and I can't find the replacement part as it shows everywhere out of stock. Part number is 44305-SJD-E20 and I wonder if there is any alternative option for that part, maybe some other honda models share the same part but under different part numbers? I found Honda OEM part but I can't afford to spend over £500 just for part alone and also wait till mid october, so any input from you guys will be appreciated.
Thank you in advance!
JZ
Edited by Outlander
Stupid question perhaps but have you tried Amazon and eBay?
Here's some other parts stores you can try, not sure if any of them will be able to help but if you have the time might be worth checking some of them.
Euro Car Parts
Motor Parts Direct
GSF Car Spares
parts-honda.uk
https://www.coxmotorparts.co.uk
https://www.lingshondaparts.com/
https://www.autoparts24.co.uk/
https://bestpartstore.co.uk/
https://www.bremboparts.com/europe/en/
hondadirectparts.com hondadirectparts.co.uk
https://www.hondaparts247.co.uk
https://nextdoor.co.uk/p/HxGL_TxXLMFM?view=detail
opieoils
carpartsforless
Parts Gateway
Or try searching in local car breakers in case you can find a second hand part.
Also I may be speaking out of ignorance here but for something like a drive-shaft I'd guess that there may not be too many alternative / non-original options out there as it's presumably quite specific and not that widely needed? In which case I'd guess that your best bet is going to be the Honda dealers or breakers for a second hand one?
I may have been wrong about that, as I see there is a GSP one, but as you say it's out of stock. I guess you could contact them to ask if they know if/when it may come back into stock.
Otherwise, how about this one from Autoparts24? Or if you scroll down on that page there are some similar ones that are cheaper - you'd have to check if they are the for the right model though.
