Hi All
I have noticed lately that my Crv has developed a squeal when depressing the Clutch Pedal, Had a good look through other Honda Owners comments on this and apparently it can be a problem on some Hondas, The clutch is operating fine, so located the Clutch Slave Cylinder and gave it good dose of WD40 and some 3 in 1 around the rubber seals and the slave cylinder piston, okay its not the same as removing the piston and doing a proper job, but the squealing noise has stopped , and a relief not to get this noise every time, I will let others know the outcome.
Have a good weekend Guys & Gals
BAZZER RN 1
  • 2 weeks later...
I sometimes have the same on my 2005 CRV I find that if I ride the clutch for a few seconds it stops it for a few weeks. I was told I'm too gentle driving and the clutch gets 'smooth'????? Alan
