Is anyone heard about gear oil change and top-up for the ENY:1??? I'm seeing posts on the internet that says it needs to be changed in intervals...
One post says "Actually, it should be changed immediately after car purchase, as it contains only transportation oil. The oil specified in the manual is sold only in China. We are using 75W-90 GL-5 oil, the amount is 1.3 liters.
So far, I have seen people use oil from the following manufacturers:
Rowe, Motul Gear 300 LS, and Yacco. I can't tell anything about others, but I think if the parameters are the same, it should be okay.
75W-90 GL-5 and only 100% synthetic."
I thought this ev was oil change or top-up free...
I would refer to your dealer and get them to investigate any concerns
At least you can also state that you questioned it if anything does go wrong with the vehicle
Register a new account
Sign in
