Morning, i have a Honda CRV 22 plate which has been in and out of my Honda garage approximately 8 times with the same issue. when i hit 63 mph i get a tremble/vibration up through the steering. the brakes and discs have been replaced, rebalanced, different wheels and tyres tried, and driveshaft changed. no result. last comment from garage was that this was something that was an issue with this model. CRV Hybrid 2 ltr all wheel drive. 24000 on the clock. any one come across this issue and advice on what i should do. still under warranty.
I would try another Honda dealership if they have not found the issue.
You could also look at the tyres - if there is a lump or deformation on the tyre or a crack or other damage on the rim then this can cause similar symptoms.
If the vibration disappears over the speed you mention then it has to be wheel imbalance
