  2. Hi, I've recently noticed that when the needle is sat between 60 and 70 mph, the needle bounces. I think the speed sensor could possibly be faulty. Can someone please tell me where the sensor is located? And is it a straightforward replacement? Thanks Simon
  3. Thanks for the replies. I’ve bought some snow/mud chains to fit and we’ll see what difference they make. I can also load the boot up with ballast if needbe (all jokes aside it may assist!)
  4. Trevor
    THE PUB
  5. Hello.i have a honda jazz year 2012.i change the battery and the sensor parking not working.i clean them and still nothing.evryone no where is locale the central box for them maybe I cant reset them.i dont have buton for them.thankyou very much.
  6. I think if you have a transmission service done then any loose or worn components will surely be picked up during the service. Let us know how you get on with it
  7. LesW
    Spare key
  8. Hi, did you get any further with fitting a subwoofer? I'm considering this myself for my hrv advance. Thanks
  9. I've just bought a new "24" plate HR-V Hybrid Advance Style which, according to the manual, has the Traffic Sign Recognition System fitted which can show both speed signs and traffic signs. However, the system only ever shows speed signs but never any traffic signs. The dealership cannot understand this and don't know how to fix it and a query direct to Honda UK unhelpfully tells me to go back to the dealership. Has anyone any knowledge of this issue or whether it is still an active system?
  10. This won't help much, but just wanted to say that in terms of obtaining parts for these (depending on what you need) it is rather tricky at times. For example, none of the scrapyards within 30 mile radius of me have any of 1st gen crv's in stock. As you've mentioned some parts are discontinued. The only hope is to keep checking eBay until something pops up, or find someone who is breaking one up for parts, but that would be eBay as well I suppose. Good luck.
  11. Not yet, although it is on the to do list. Lack of time is a factor. Though the transmission is changing gears smoothly and there is no clonking when engaging gears. When I eventually get round to changing the fluid I will put an update up. The fluid itself does not look too bad. It is not new, I can tell that much, but not too bad. Is the filter actually a serviceable item on these transmissions, or can you only access it when you are rebuilding the gearbox?
  12. it would be very helpful to have a picture of the windscreen washer pipe layout under the offside rear floor well. Two elbows I believe?
  13. Earlier
  14. That's great to hear, thanks for letting us know.
  15. Have you tried a new (quality) battery as if the old one needs charging periodically it may have faulty cells and this can cause the issues you are describing (if the battery cannot deliver a high enough voltage on start up then this will flag the lights)
  16. If you decide to sell it then you are welcome to advertise it in the Cars For Sale section of the forums https://uk.hondaownersclub.com/forums/forum/58-hondas-for-sale/
  17. Can you not get them reconditioned.....I'm sure there are still some companies that can do this service
  18. Sounds like the ignition system is being powered to the accessory setting on the key, I would check any relays and see if they click when they should and substitute like for like to see if it makes any difference to the clock display being permanently on
  19. Sometimes it can be a tough one to diagnose. The best way would be to attach a multimeter to the battery and then systematically remove fuses until the current drops then you'll know where the faulty circuit is located
  20. Which engine does it have?
  21. Does the battery need coding into the vehicle - e.g. vehicle may have to recognise new battery voltage otherwise will still be reading the old voltage If in doubt, worth checking to see if it has this function
  22. My dad is looking to sell his much loved Honda Civic Aerodeck V Tech X reg, 55000 miles. New clutch and tyres. Would anyone be interested?
  23. can anyone help me find the radio code. details in pic.
  24. Hi All, my fob has died. I have changed the battery (checked it in my other fob it works fine) i can get a fob online or from a breakers yard ( i am not going to pay the £600 the dealer wants) but it will need to be paired to my car. Can i do this myself or not? You tube has been unhelpful!
  25. Hi All, My fob has died (2020 CRV) i have replaced the battery, checked the battery in my other fob (it works) i have come to the assumption the fob is knackered. A new fob from the dealer is £600!!!! the key can be swapped into amother fob but the fob i assume will need to be programmed or paired to the car. Can this be done by myself or do i have to pay a dealer to do it? Thanks all
