I would keep trying the release fluid and see if it does eventually free up Alternatively, try gently moving the wheel backwards and forwards in small motions as you try to the key in the lock
Hi, I've recently noticed that when the needle is sat between 60 and 70 mph, the needle bounces. I think the speed sensor could possibly be faulty. Can someone please tell me where the sensor is located? And is it a straightforward replacement? Thanks Simon
PaulStafford1984 replied to PaulStafford1984's topic in CR-V 2001 to 2006
Thanks for the replies. I’ve bought some snow/mud chains to fit and we’ll see what difference they make. I can also load the boot up with ballast if needbe (all jokes aside it may assist!) -
Honda HR-V 2002 1.6 automatic judder when starting off.
Trevor replied to middleportreddie's topic in HR-V 1999 to 2006
I think if you have a transmission service done then any loose or worn components will surely be picked up during the service. Let us know how you get on with it -
New battery drained... possible electrical problem?
Trevor replied to Johnny2Hondas's topic in 1982 to 1994 Accord
Sounds like the ignition system is being powered to the accessory setting on the key, I would check any relays and see if they click when they should and substitute like for like to see if it makes any difference to the clock display being permanently on -
Sometimes it can be a tough one to diagnose. The best way would be to attach a multimeter to the battery and then systematically remove fuses until the current drops then you'll know where the faulty circuit is located
Which engine does it have?
Does the battery need coding into the vehicle - e.g. vehicle may have to recognise new battery voltage otherwise will still be reading the old voltage If in doubt, worth checking to see if it has this function
