Honda HR-V 2002 1.6 automatic judder when starting off.
Trevor replied to middleportreddie's topic in HR-V 1999 to 2006
I think if you have a transmission service done then any loose or worn components will surely be picked up during the service. Let us know how you get on with it -
Trevor replied to PaulStafford1984's topic in CR-V 2001 to 2006
The CR-V 4 wheel drive works on an 'as and when' basis....e.g. it kicks in if it loses traction so is technically a 'Crossover' rather than an 'All Wheel Drive' vehicle As Alan has mentioned, a lot of it comes down to tyres - if they are not off road tyres then you won't get any traction once the treads fill with mud - Last week
New battery drained... possible electrical problem?
Trevor replied to Johnny2Hondas's topic in 1982 to 1994 Accord
Sounds like the ignition system is being powered to the accessory setting on the key, I would check any relays and see if they click when they should and substitute like for like to see if it makes any difference to the clock display being permanently on -
Sometimes it can be a tough one to diagnose. The best way would be to attach a multimeter to the battery and then systematically remove fuses until the current drops then you'll know where the faulty circuit is located
Which engine does it have?
Does the battery need coding into the vehicle - e.g. vehicle may have to recognise new battery voltage otherwise will still be reading the old voltage If in doubt, worth checking to see if it has this function
