It's an easy fix; the auto transmission fluid needs to be changed at regular intervals (specific CVT requirement) and when the fluid is losing it's edge the judder is noticeable. Make sure that you use genuine Honda CVT fluid, it's an easy enough job and I've been doing my wife's car ever since the dealer warranty expired; it's 21 years old now.
Hi I've recently bought a Honda CRV (my third Honda CRV in the last 10 years) but in this particular car, my oil light comes on every 1,000-1,500 miles. When I check the dipstick, there is no oul left so I have to keep topping it up. I've read the handbook which states that I may be expected to put 1 litre of oil in every 625 miles. Has anybody else had this problem? Regards
I have a UK 2005 Honda Accord 2.4. Fault: (1) My VSA activation indicator warning triangle light comes on and stay on. (2) The VSA system indication warning light also comes on after a few 100m driving and stays on. I took my care to my local garage and they got an Error Code of 84-1 but their diagnostics tools doesn't allow further investigation and provides several options of possible causes. Therefore they are unable to fix the fault and suggested my car need to go to a Honda Garage or Honda specialised. Any idea's
I would keep trying the release fluid and see if it does eventually free up Alternatively, try gently moving the wheel backwards and forwards in small motions as you try to the key in the lock
Hi, I've recently noticed that when the needle is sat between 60 and 70 mph, the needle bounces. I think the speed sensor could possibly be faulty. Can someone please tell me where the sensor is located? And is it a straightforward replacement? Thanks Simon
PaulStafford1984 replied to PaulStafford1984's topic in CR-V 2001 to 2006
Thanks for the replies. I’ve bought some snow/mud chains to fit and we’ll see what difference they make. I can also load the boot up with ballast if needbe (all jokes aside it may assist!) -
New battery drained... possible electrical problem?
Trevor replied to Johnny2Hondas's topic in 1982 to 1994 Accord
Sounds like the ignition system is being powered to the accessory setting on the key, I would check any relays and see if they click when they should and substitute like for like to see if it makes any difference to the clock display being permanently on -
Sometimes it can be a tough one to diagnose. The best way would be to attach a multimeter to the battery and then systematically remove fuses until the current drops then you'll know where the faulty circuit is located
Which engine does it have?
Does the battery need coding into the vehicle - e.g. vehicle may have to recognise new battery voltage otherwise will still be reading the old voltage If in doubt, worth checking to see if it has this function
