2001 honda civic coupe 1.7 vetec
Definitely a rare one to see on the roads nowadays - feel free to post an advert in the forums to see if you get some interest from any members. Maybe post up some pics of the Civic and some more info to assist with selling it.
Heater motor fan inop.
Best thing is to see what the part number is (possibly label or sticker on the motor) and cross-reference to Civic motor on eBay
HAPPY NEW YEAR...
We couldn't afford to waste good(?) beer by spraying it up the walls - you were obviously a wealthy person in the '70s :-)
DRL Jazz 2014 v-tec.
Most vehicles nowadays have the facility to retrofit accessories and most of it is in place from the factory (as in wiring loom, fuses, etc). If they car was taken to the dealer for retrofitting lights, etc then it is a case of fitting the lights, putting power to the lights (fuse, switches, etc) and then programming it into the CanBus system to activate it.
1998 Civic Aerodeck 1800 VTI
They used to sell CV gaiters that were split and you placed them over the CV joint and ran glue along the length to secure it along with the clips each end. They sort of worked but were a little bit rigid so would pull off the joint but at least they lasted long enough for an MOT test :-)
Good and bad news then ! CV gaiter is relatively cheap and easy to sort ABS and SRS lights - I would look for any connections under seats (for the SRS) and under the bonnet and each wheel (for the ABS). I believe there is a limited OBD interaction that you can read codes for engine but not sure that it goes deep enough for SRS and ABS. Sometimes it is a common factor such as poor connections on the battery or earth connections to the chassis
Preventative Maintenance
I'm not aware that these components would in fact fail due to inherent faults and are not necessarily maintenance items. The turbocharger is best maintained by ensuring the air filter is in good condition and also the engine oil is of the correct grade and quality.
Hi John The most crucial parts to consider changing as a maintenance task are the air filter, oil filter, cabin filter and also the fuel filter (which is a bit of a fiddle to change but quite straightforwards. In addition to these service parts I would advise to change the rear diff oil with the correct fluid from Honda as this can manifest as clunking when turning in on a sharp corner (e.g pulling into a driveway) which tells you the fluid needs replacing. Beyond that, the 3rd generation CR-V is a superb vehicle and there is no reason it shouldn't go on for many years ahead.
what is this? 2024 model
I would be tempted to top it up and see if that changes the reading and especially when it gets down to this level again
Who remembers these?
Loved the adverts of the era as they were memorable - even after 50 years I can still sing the song that was played or the taste of the drink, etc.
I seem to recall using a module from another manufacturer to resolve the parts supply issue at the time - could have been Rover or similar manufacturer that used the same system - at least it gives you an opportunity to widen the search. Searching by Part Numbers would be best to get straight to the correct part
New to Honda
Hi Ivan....welcome to the Club I'm sure you will be pleased with the Jazz and its reliability and build quality Good to have you onboard!
Dim low beam
Any upgrade in bulbs is good in my opinion. Whether they bring a noticeable difference to the table may be good but unlikely to be any worse than the standard halogen bulbs
Tyre pressure monitor on 2013 Honda civic es i-vtec 1.8.
Maybe worth increasing the pressures by a couple of psi to see if this extinguishes the warning. You can always let out some air but also good to check you don't have a slight leak on one of the tyres. Resetting the pressure settings on the vehicle may just be masking a fault in one of the tyres Also, ensure you check the tyres when cold
Catalytic converter replacement
That appears to be the earlier version with single oxygen sensor that only measures earlier Euro standards emissions. The later version which is on the car measure both pre and post catalytic converter oxygen levels to compare and adjust feeling to optimise and measure the efficiency of the cat.
