paulandsab Posted March 19, 2020 Share Posted March 19, 2020 Hi ! I'm in the UK and have a Honda FRV 2005. So basically my heater blower has stopped working. I have replaced the resister pack and that has not fixed it. The fuse is fine too. So now I am trying to replace the actual blower motor itself. I have unscrewed the 3 screws holding it in place but it cannot drop down far enough for me to pull it out because the ECU is in the way. So, now I need to remove the ECU from its casing, which is directly below the blower. Once this is removed there will be enough room for the blower to drop down. There are 2 screws/bolts at the front of the ECU, one on each side, I have taken these off however there is something else holding the ECU in place as it will not slide out of its casing. It feels like something right at the back but I can't see or feel anything. any advice please on how to get the ECU out ? Thank you ! Quote Link to comment Share on other sites More sharing options...
Trevor Posted March 20, 2020 Share Posted March 20, 2020 Hi....welcome to the Forum I too have recently tackled a similar task on a 2005 CRV and although I have not yet removed the heater motor I have diagnosed it as the motor at fault....power going to the motor but not working, has to be the motor. Would be interested to know what you eventually find it to be as I have to tackle this job in the near future Quote Link to comment Share on other sites More sharing options...
WAWAW Posted August 2, 2020 Share Posted August 2, 2020 Ive also just had the same issue with the blower not working. I replaced the resistor after I was told it was the issue only it didn't fix the problem. Had an auto electrician look at it and checked the motor was still in good working order by putting a direct live to it. Eventually located the problem which was the circuit board behind the heater blower controls on the dash. Bit of a pain to remove (but the auto electrician did that for me) but simpl enough to put back together with a new control unit sourced from eBay. Total cost £140- auto electrician was £100 of that. But we'll worth it to have blowers working again! 1 Quote Link to comment Share on other sites More sharing options...
