sometimes the alarm works, sometimes it doesn't
randomly goes on sometimes and when i use remote to lock  then it locks but doesn't flash and alarm symbol in dashboard not showing?
can anyone help or advise?
I would check that each door and boot sensor is working by seeing if it illuminates the interior light and extinguishes it when the door is closed
If one or more are not working properly then it may be the door switch or wiring at fault
On 4/27/2020 at 1:25 PM, b4u2 said:
Thank you.
I have already checked and it's not that causing the  problem.
Its probably then a case of going through the wiring and connections checking for any breaks or poor connections
  • 3 weeks later...
I know that the alarm will sound if there is a problem with its backup battery, which is inside the alarm...
  • Like 1
  • 4 months later...
Register a new account
Sign in
