2007 (gen 3) Honda CR-V EX 2.2 i-ctd-i 6 speed manual. The dash clock in the navigation/entertainment centre will not retain time after it is set and then the ignition is turned off, BUT it will keep the time if the ignition is not turned totally off even with the engine not running. If the ignition is kept on Aux, the run position or the engine is running it is fine.
Is there a fuse or relay that controls this? I have disconnected the battery, waited 30 minutes then reconnected it, reset the radio code , the ECU then reinitialised the security system but it had no effect. 8 attempts so far and always the same result.....HELP please.
we all have the same problem Honda USA/UK are aware, there is a thread on this already!
Does this affect certain years? Mine is a 2015 CR-V and is ok.
not all models only certain generations as far as i'm aware mine is 3rd Gen
