DavidW Posted March 23, 2023 Share Posted March 23, 2023 I have a 2014 (64 plate) Jazz 1.4 ES+ I-Vtec CVT GG6 according to the V5 and have not been able to verify if it is CanBus fitted or not. WWW sites give conflicting information! I would like to fit reversing sensors ( I know its only a small car!) Quote Link to comment Share on other sites More sharing options...
Trevor Posted April 3, 2023 Share Posted April 3, 2023 It will more than likely have a certain amount of CanBus within the wiring system for a vehicle of that age. The easiest way to identify if it is CanBus wiring you are tapping into is it will more than likely be 'twisted pair' wires and as long as it doesn't have any yellow covering over the wires which is usually SRS and should not be interfered with in any way Usually, with CanBus wired ancillaries, they will need programming into the vehicle for identification into the system Quote Link to comment Share on other sites More sharing options...
DavidW Posted April 5, 2023 Author Share Posted April 5, 2023 Thanks Trevor I'll have a hunt round the rear lighting clusters. 1 Quote Link to comment Share on other sites More sharing options...
