Barrie Posted August 18, 2023 Share Posted August 18, 2023 My 2016 Honda CRV has been driving me wild with a sometimes quite loud hum/squeel from the front nearside wheel when I enter a left hand corner. I have replaced the discs and brake pads, checked all the suspension etc but cannot detect the problem. Its not constant but only occassionely normally after travelling. Thanks over 10 miles. Any help would be most appreciated . Thanks Barrie Quote Link to comment Share on other sites More sharing options...
Trevor Posted August 18, 2023 Share Posted August 18, 2023 Possibly wheel bearing but if you were entering a left bend then it would be the offside bearing unless it is the rear one. Really need to jack up each wheel and spin to hear if it is rough and/or noisy, although most of the time this only occurs under load when cornering 1 Quote Link to comment Share on other sites More sharing options...
Sally Kristina Posted January 13 Share Posted January 13 I had the same noise it was the tray under the car that had come off one of the clips. Quote Link to comment Share on other sites More sharing options...
