Alan gsd Posted July 24 Posted July 24 My 2005 CRV has a near side (is that left or right??} leaking headlight washer, knowing what I'm like with anything DIY is it an easy job to do and any suggestion where to get one from please, like it to be a Honda part not some Chinese bit!!! Alan
Alan gsd Posted July 25 Author Posted July 25 following on from the above, I've checked the fuse, is there a relay for the washers? The rear is working but both front are not i've now found and don't really know fpr how long, Done the headlights on dipped and all the other tests Alan
Trevor Posted August 5 Posted August 5 I'm sure it takes the water feed from within the front windscreen washer reservoir (when the lights are on and the washers are applied Parts would be OE and no longer available so I imagine so a scrapyard would be best source for replacement jet
Register a new accountSign in
