Alan gsd replied to PaulStafford1984's topic in CR-V 2001 to 2006
Hi Paul, the more I look into the 4 wheel drive the more confused I get, we need Trevor or BAZZER RN words of wisdom to clear up if the 2005 CRV are all 4 wheel drive and if there is anyway of knowing when it kicks in. -
Hi all again. I have this annoying shudder when starting off from stopped. It only lasts a second, then is gone, until your taking off from being stopped again. The car runs perfectly at all speeds in every other way. If it were a manual car, my first guess would be to think it would be the clutch, or as its a 4 X 4 prop bearings. May be significant, but it only does this after it has been running at least a few minutes, perfect when stone cold, no shudder/judder. I am going to try and discount the gearbox, by having a fluid and filter change. If that has muck in it from 86000 miles of use, (no evidence the fluid has ever been changed) that might mess around with the oil pressure and influence the take off. I will report here again once that has been done. Is there any way I can electrically disable the 4 x 4 for testing to see if its that, which is making the shudder? If anyone has had the same type of problem, please let me know what happened, and how you fixed it. Also if you have any ideas please let me know. Anyway, thanks for reading this, and any help would be greatly appreciated. Eddie
New battery drained... possible electrical problem?
Trevor replied to Johnny2Hondas's topic in 1982 to 1994 Accord
Sounds like the ignition system is being powered to the accessory setting on the key, I would check any relays and see if they click when they should and substitute like for like to see if it makes any difference to the clock display being permanently on -
Sometimes it can be a tough one to diagnose. The best way would be to attach a multimeter to the battery and then systematically remove fuses until the current drops then you'll know where the faulty circuit is located
Which engine does it have?
Does the battery need coding into the vehicle - e.g. vehicle may have to recognise new battery voltage otherwise will still be reading the old voltage If in doubt, worth checking to see if it has this function
Thanks for the reply,but sorted now -
Can only find two listed - Fuse 3 (20 amp) in dashboard fusebox
