Baz Posted May 15, 2022 Posted May 15, 2022 i need to check valve clearances on my 2007 i-ctdi 2.2 EX as i dont know when they last checked, anyone know what the correct clearances are? any help most welcome Baz
Trevor Posted May 16, 2022 Posted May 16, 2022 You would not really need to adjust valves on modern Honda engines. Unless you have issues with noisy valve-train then it shouldn't need touching
Baz Posted May 21, 2022 Author Posted May 21, 2022 On 5/16/2022 at 2:15 PM, Trevor said: You would not really need to adjust valves on modern Honda engines. Unless you have issues with noisy valve-train then it shouldn't need touching the reason i asked was because in the Handbook it says valve clearances should be checked every 25,000 miles on petrol models but no mention of Diesels,so if Diesels dont require checking how would you know you have a tight valve untill it burns out.
Register a new accountSign in
